Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Audio/Visual Electronics
Register Forgot Password?
Old 01-16-2007, 11:21 PM
Junior Member
Default 1996 LR 4.0 sub install need help
ok i have a 1996 LR 4.0 it has a clarion cd changer in it and the stock raido. My first ? is what wires do i tap in to to put a line converter in. i would liketo ad more subs and what wire do i use for a remote wire. next ? what size speakers do i have in my doors i was thinking that i night upgrade them to. OOOO how do i get in to the speakers do i have to take off the door panel or do the covers just pop off thanks for all the help in advance
Old 01-17-2007, 11:15 PM
Junior Member
Default RE: 1996 LR 4.0 sub install need help
anybody ???
Old 02-21-2007, 04:39 PM
okdiscoguy's Avatar
Senior Member
I have a 97. I replaced the door and rear sails with 4" Boston Acoustics. The 2 6 1/2's in the tailgate I just unhooked and ran the line to a new amp and sub. I replaced them, but it wasn't enough fo what I wanted. The low line to the amp is not low enough to usewith the RCA's, you have to use a line converter. If you are hooking up an amp, everything you need is there, besides the high amp + wire. either use the high in, or a converter. Oh, and FYI, I put 2 8's under the front seats. Plenty of room, but I don't have the changer there. If you do, you might have a problem.
__________________
RAVE
Good Oil
2003 Range Rover HSE with 2008 trim
2010 GLK 350 Mercedes
1990 VW Cabriolet - Lake car...
1997 Discovery SD-7 to put the boat in.
Tags
1996, range, rover, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
