Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Audio/Visual Electronics
Register Forgot Password?
Old 07-04-2008, 09:50 PM
99LRDisc's Avatar
Senior Member
Send a message via Yahoo to 99LRDisc
Default Discovery LED Upgrade
__________________
99 Disco I 133k body - 67k engine
235/85/16 Goodyear Wrangler Duratrac, 16" All Steel Black NATO rims, complete OME HD suspension w/ damper, 4 orange driving lights, Southdown Steering Guard painted black, Viper 5901
Old 08-14-2011, 09:20 AM
Junior Member
Very nice!
By any chance would you be able to help me out with the type of bulbs you used? I want to do the same to my 02 Discovery.
Thanks!
Old 08-14-2011, 09:43 AM
Senior Member
superbrightleds.com has ones that will plug in (called festoon), I also found some generic in the blister pack aisle at one of the auto parts stores, I soldered mine in. Much more light, and way less amp drain on MFU. And my MFU had failed because the big transistor in it that is used to dim the lights has no heat sink, had hole melted in the plastic MFU case. Engineers!! Being an old guy, I need all the light to check my Depends after first encounter with the "Death Wobble".
__________________
Old 08-14-2011, 07:37 PM
dgi 07's Avatar
Senior Member
DGI 07
WAIT....dont order yet....i just went thru this. there are two different bulbs for the interior lights....the center one you can get at superbrightleds. its a 36 mm bulb i believe. you are also gonna need a 39-40mm feston for the front and rear as well.
__________________
2001 Land Rover Discovery SE 81,5000 miles(His)
2012 Mercedes Benz C250 Sport (Hers)
Have you lubed your driveshaft lately?
Diagnostic Technician for the Three Pointed Star. Got questions, just ask.
Old 08-14-2011, 07:45 PM
dgi 07's Avatar
Senior Member
DGI 07
to the OP, what bulb type did you us for the vanity mirror bulbs?
__________________
Old 08-15-2011, 09:19 PM
Junior Member
Hello dgi07,
So is there any way you could list out the bulbs you used and the location! Thank you...that you be of very great help so I know exactly how much of each bulb to buy.
And I'm also interested in what the vanity lights are also.
Old 08-16-2011, 08:33 AM
dgi 07's Avatar
Senior Member
DGI 07
Quote:
Originally Posted by richyrich0607 View Post
Hello dgi07,
ok, if you go to superbrightleds, and plug your truck into the bulb finder, you will see the one bulb they listed for all dome lights. It will only work for the center light. you will need a feeston type bulb thas about 3 mm longer than the one they have listed. i didnt do the vanity lights because they are meant to be softer lights for a woman to adjust her makeup as needed. and as you can imagine, my wife frequently likes to ride in my truck so i left those alone.
__________________
Old 12-13-2011, 01:39 AM
Junior Member
Just an FYI...
I used the 3710-CWHP3 for all 3 dome lights from SUPERBRIGHTLEDS.COM. They fit, but you might have to spread the connectors just a bit (not much). I was trying to save money (but in hind sight) i probably would have bought the 3710-xHP6 for the very back and middle dome light. Hope this helps.
here are the links:
3710-xHPx High Power LED Festoon Bulb Specifications
Old 12-13-2011, 01:46 AM
Junior Member
BTW...
I have a Disco 2 2002.
@ dgi 07, I agree about the vanity lights. ...they are for the ladies and softer light means "happier reflection" lol. However you could maybe try the WARM WHITE LEDS.
Old 12-13-2011, 02:22 AM
Junior Member
....also
Is your truck an LSE? Curious because it seems by your pictures you have lights in the cargo-bottom area where my SD only has an empty plastic grill.
Tags
2001, 5901, add, discovery, duratrac, extra, goodyear, ii, land, led, light, lights, rover, upgrade, viper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
