If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
How do I get into instrument panel to replace bulb
There is a bulb that illuminates the odometer that is out and I need to know how to get into the panel to replace, I didn't find instructions in the Rave Manual.
I don't know what model yopu have but ussally you remove the two peice cover that makes up the steering colum cover . After you remove that you take off the plastic cover of the ip cluster, some screws...and then your at the cluster.... 2 screws. On each side
__________________
2003 Discovery SE
125k on frame ,58k on 04 4.6 engine, CDL equipped, Hella 3000's,4 Hella 500ff on roof rack,Black 18 inch hurricanes, HFT oil pressure gauge, Custom roof rack, 99-02 brush bar, headlight guards, taillight guards, travall ladder, rear step, two tone leather interior, headliner!, TB bypass,180' inline thermostat, D1 wiper arm conversion, rear tractor light
Its been burned, baked, smashed and broken... i still love it....
there are two screws right behind the wheel above the steering column. undo those. pop out your swiches on both sides and disconnect the wiring harness make sure to write what color is for what switch. there are two tabs holding the console cover down. should pull striahg tforward. you will see 4 screws holding the console down. undo those 4. theh plastic cover comes off with 5 tabs holding it to the speedo. there are two more wiring harnesses holding the speedo into the ecu. disconnect both. a few m0ore tabs hold the back on pop those off and you will have access to the bulbs. there are four bulbs. three white and one blue. the blue is your high beams the whites are your main back lights. good luck
__________________ -Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
