Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
radio noise when charging devices
Old 06-29-2015, 03:22 PM
TOM R's Avatar
Default radio noise when charging devices
not sure if this is noise or its blocking the signal somehow but i have a 3 socket adapter plugged into the cig lighter and when i plug in the usb to charge my phone its like the radio no longer gets reception unplug radios fine
do i need a noise suppressor for the cig lighter circuit?
Old 06-29-2015, 10:00 PM
robertf's Avatar
you may want to try adding a ferrite bead around the wires going to the charging port. I don't know if this will solve it, but its on my list of things to try. Ios devices seem to be terrible about this, while an XM unit plugged in to the same port doesn't do this.
Old 06-30-2015, 03:44 PM
TOM R's Avatar
ok you mean that plastic tube clamped around the wires on some devices?
Old 07-01-2015, 06:44 AM
robertf's Avatar
yes, but the plastic is just a cover. they are iron. they are under $1 at any electronics shop ive been to
Old 07-10-2015, 08:59 AM
TOM R's Avatar
i did order somne beads, but the issue resolved itself when i installed the power ports in dash, still using same usb charger but no noise?? guess it was the power splitter thing i was using
Mark G
10-29-2012 09:02 PM
steve
02-18-2009 12:02 AM
bonedoc
06-13-2007 03:24 PM
sabsr1954
10-24-2006 04:25 PM
RTLimo
08-15-2005 12:42 AM
Quick Reply: radio noise when charging devices
