Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Defender
Register Forgot Password?
Old 02-17-2008, 12:39 AM
Junior Member
Default 07 Defer lift problem?
Well, I recently bought an 07 defender and had it lifted 30mm's. IT started having some drive line issues with grinding in the gearbox. It lasted a few weeks so I took it to the mechanic who put it down to a 20mm lift-it still grinded just as badly. Then we had to make it stock again. Oh, a suspension mod, not body.
Has any one else tried to lift a new model Defender succesfully or unsuccessfully?
Thanks,
Xav
Old 08-23-2008, 11:42 AM
Junior Member
Default RE: 07 Defer lift problem?
You will need to fit a double cardon joint front prop-shaft to correct the geometry of the drive line. One can be purchased at QT Services. www.qtservices.co.uk
Tags
defer, land, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
