If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
200Tdi timing problem - major headache, help needed urgently
Ive got major headache with my 200tdi. Just replaced timing belt as snapped. Reset the injection timing as it should be, lined up the crankshaft and camshaft as they should be, per Land Rover workshop manual. When put bakc together it will just about start after a couple of turns (maybe 4 or 5), but then runs really rough almost like fuel staved. No response at all on the throttle. Engine almost lollops if you know what I mean. No power what-so-ever.
Suspected blown headgasket as was burning oil, so replaced that. Oil burning is solved I think, but engine still running same.
Replaced injection pump with a really good, proven unit in case pump was knackered.
Fuel system thoroughly cleaned and bled, injectors proven chucking fuel in.
I proved TDC is correct with the crankshaft damper on.
Please help, what am I missing? Im guessing its got to be some sort of timing issue, perhaps wear in the engine meant previous owner moved sprockets from what the landrover manual says? Im really concerned that it wont respond to the throttle. I thought if the timing was out, that it should still rev up?
RE: 200Tdi timing problem - major headache, help needed urgently
THE BELT BROKE????
, then unless jesus himself was with you theres a valve issue. Have the compression tested
The valve job it self not so bad, but look at the piston crowns and make sure non of them got a smiley so deep the it is venting into the crankcase. scott
__________________
Land Rover master tech guild number 1121, BMW master tech Audi master tech, currant ase's and l-1
That's not likely to happen with a Tdi... the valves are vertical and the pushrods are made out of brie, you will have to replace the pushrodsbut valve and piston damage from a broken cam belt on a Tdi is really quite rare.
