Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Defender
Register Forgot Password?
Old 07-17-2011, 11:02 PM
Junior Member
Default 95 D90 with random engine kill
Looking for any common knowledge / known problems on early D90's or Disco S1's... reasons for engine to quite at randome times (or not start).
Might be off road or on road, hot or cold. Rough or smoot ride. Power gone and Tack goes dead.
Vehicle has remote amplifier. New coil. Can't find loose wire near coil/amplifier. Don't know if it is ignition or fuel starved. But when it goes dead tack doesn't move when cranking and only a little fuel smell from tailpipe.
Oh and does anybody know the engine control sequence. The ECU seems ot have some (2) remote relays. One controls the fuel pump and shuts it off if the engine doesn't start. I don't know what the other does.
Digger,
73 SIII-88, 95 D90
Old 07-18-2011, 07:44 PM
Senior Member
one is injectors and one is fuel pump. its always a good idea to replace them in pairs.
seen them go at times one at time and sometimes together.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
d90, defender, engine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
