I use an old radius arm to axle bolt cut off to about 70mm and ground to a blunt taper as a locating pin. Then place a jack under the radius arm just below the axle and sometimes I need to pry between the radius arm and axle to move it in to position.
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
