Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Defender
Register Forgot Password?
Old 07-17-2010, 08:34 AM
Junior Member
Default Electrical problem: don't know what else to try
Hi,
I recently had a small accident with my Defender 110 Td5 of 1999 that damaged all the rear right lights.
I could fix all except the turn signal. The shock caused a short circuit in that lamp connector that made the alarm system go crazy and inmobilized the engine shortly after the accident. I eliminated the shortcircuit, replaced some fuses and solved the alarm/engine problem.
BUT I realized that now none of the turn signals work (not only the rear right one). Moreover, the fuel gauge and the coolant temperature gauge don't work. All these elements have in common the white-green cable.
I have checked all the fuses and they are ok. Now the cables going to the rear right turn light (white-green and black) are not connected to anything as I haven't put the new lamp yet.
I use the truck everyday and I cannot drive on main roads without side lights, so I would really appreciate your help.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
