Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Defender
Register Forgot Password?
Old 08-11-2008, 09:56 PM
Junior Member
Default front diff issue
My 94 front diff suddenly has a hole in the bottom of the pumpkin. Looks like a gear inside has broken off somehow and is sticking out a bit. I can and did push it back in with a bit of force, filled it back to the top, and drove it back home - Leaking.
Anyone have experience rebuiding the diff? I don't but I'm gonna repair it myself (I know engines but never had to deal with running gear). I assume that I can weld the pumpkin hole closed once I pull, id, and replace the bad gear. Any tips would be much appreciated. Thanks.
Old 08-12-2008, 10:31 AM
Send a message via Skype™ to Disco Mike
Default RE: front diff issue
Yes, you can repair the diff case. Are you running lockers or are you stock? If not you should be able to rebuild or replace the third member.
Let us know what you find when you open it up.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 08-12-2008, 12:20 PM
Junior Member
stock running gear pushing 285's (suspect that might have some contribution- they've been on for a few years). No experience weld a pumpkin hole (size of a cashew) but I figure that draining and cleaning out all lube will allow welding without fire - And that way keep it in the drive at home.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
