Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Defender
Register Forgot Password?
Old 03-23-2008, 08:06 AM
Junior Member
Default light switch replacement
Hello,i am trying to replace my headlight switch and it appears that the steering column goes through the centre of it.How do i dismantle the steering column?i have a 1998 defender 110 tank you
Old 03-24-2008, 01:13 PM
Member
Default RE: light switch replacement
Hidav1sutcliffe.
Are you refering to the headlight switch or the dip switch?To replace the dip switch,you have to remove the steering wheel.The headlight switch has a nut under the rubber that holds it onto the bracket.
Regards
Marius
Tags
110, colum, defender, headlight, land, light, replace, replacement, rover, steering, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
