New Defender owner (Santana, actually)
Hello,
I spent over a year considering options for buying a Defender 90. In the end, I decided to pick up a Santana from Spain. It is LHD and has zero rust being the major advantages. The price for the spanish version was also significantly lower.
1988 model with 166,000 KM 2.5 NA Diesel 5 speed.
The most significant difference I have found is it has leaf springs whereas its British brother uses coil springs.
Does anyone here know of any significant differences?
I also would like to upgrade to disc brakes all the way around. Does anyone know which years of Discovery work best for axle assembly transplant. As it has leaf springs I will just cut off the spring perches. I just want to be sure there is nothing that is "deal breaker" in transferring the axle assemblies from a Discovery.
Thanks in advance!
Terry in St. Louis
Thanks in advance!
Terry in St. Louis
Hello,
Thanks in advance!
Terry in St. Louis
Thanks in advance!
Terry in St. Louis
Should have got the 90 or an SIII which is essentially what a Santana is.
Putting coiler axels in a leafer can be done, but they are a bit wider I think, which is why the Defenders (or 90/110 if you must) have fender flares while the series rovers did not.
If they are stock series type axles, there are disc conversions out there. Of course like everything else without much demand, they are expensive.
terryjm1 (06-13-2015)
Amazingly almost everything this the same.
Also, the 94-98 Disco axles appear to fit perfectly. However, if I stay with the leaf springs I will have to cut off the leaf spring mounts and make some other minor modifications to the axles. It would not be greatly difficult to buy the factory parts to convert to coils.
The most impressive aspect is there is literally no rust!
