1193, 1314, 0300 codes codes codes.
Old 06-28-2013, 08:29 AM
csp's Avatar
csp
csp is offline
Default 1193, 1314, 0300 codes codes codes.
Tons of reach.. New NGK plugs & wires, Rotella Oil,etc.. Next step. New thermostat, Seafoam engine, two new o2 sensors, Clean TB, clean IACV, make sure my cooling fans are working.
97 Diso I. Running good . Got up drove down the road , engine light came on. Wouldn't go over 50-55 mph. I would have to let off the gas in order to pick up speed. Back fire, spuddering, etc.. Temp Guage went up n down.. From half to 3/4 back to half.. Crazy.. I just got a full tank of gas and seafoamed. The tune up was done a few weeks ago..
Dash lights on. Check Engine, SRS, ABS.. New brake pads .. When stoping I hear a band winding sound and then they finally catch. Normally after that they are fine (some times)..
Ok Rover Experts.. Lets see if we can fix this thing...
Old 06-30-2013, 08:32 AM
csp's Avatar
csp
csp is offline
The sound of crickets...
Old 07-01-2013, 07:33 AM
fishEH's Avatar
P0300 Misfire On Multiple Cylinder
P1193 Oxygen Sensor Heater Circuit Open Downstream
P1314 Misfire Catalyst Damage Fault Bank B
My guess is you have a bad upstream O2. Downstream O2's really shouldn't matter from what I understand. I say replace the upstream O2's. But first check all your plugs/wires.
ABS light, I wouldn't worry about. Pull the ABS fuse then pull the dash light.
SRS light, this comes on when the battery is dead. Needs to be reset with a TestBook, or pull the dash light while you're pulling the ABS dash light.
Shawn Cross
12-21-2012 07:17 PM
Maytag
07-21-2012 05:00 PM
black sheep
05-02-2012 06:58 PM
kayaku
09-27-2008 02:02 PM
damon0809
04-16-2007 05:14 PM
Quick Reply: 1193, 1314, 0300 codes codes codes.
