1994 Disco..crank but no start
See attached page from RAVE electrical guide. When the ignition key is turned, battery volts should appear on one side of the spark coil. Check that fuse F3 on one of the small panels under the dash. The Main Fuse that feeds that is MF 5 under the hood, a 60 amp bolt in fuse.
Also be aware that every post might not be read, sorry for the delay; the rest of the partz vulturez must have been at the boneyard or asleep on the high banches of the shade tree.
Just tested coil..I'm getting a flickering light on negative side so this tells me it's being controlled and powered by the ignition module..I get spark so I know I have a good coil..
I don't have a fuel pressure tester so I depressed tire valve and fuel squirted out across the engine..so I'm getting fuel pressure..I'm stuck.bad egr?
