If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
I am still having an issue with the oil "idiot" light coming on after my rover is warm and cruising - I had taken her to a local goodyear shop and payed 100.00 for a supposed High End (royal purple) 15w40 oil change and Filter -
While changing out the waterpump - I noticed the oil filter was a cheap off brand. I checked the paper work for the oil change and the tech that did the work wrote down 5w30 - I have less than 400 miles on this oil change but it's been 3 months since the work was done.
My question is - how much oil does the 3.9 engine take?
Going to go with the Shell 15w40 this time, and do the oild change myself.
Don't want to by 3 gallons is I only need 2.
Thanks for your input..
Trav...
__________________
1994 Land Rover - Discovery - V8i - 95k
Newbie to the Land Rover world
Son of God
By the Blood of Jesus Christ...`
Someone will likely post it up, but it may be time for an oil pressure test. It's outlined in the RAVE and has been posted up on this board in the past.
Good luck!
__________________
'94 Disco - Lots of mods and dents, scratches and scars.
Just changed mine (4.0) and I use a jumbo oversize WIX filter, took seven quarts of 5W40 Rotella. Eric is right about fill up the filter, I counted 10 seconds before light went out without doing that (dumb and dry). But now light goes out as soon as I release the key, even before the brake light goes out.
