4wd gear selector
#22
Well, I was able to put the driveshaft in. Do you guys have any recommendations on how to tighten down the bolts and nuts easily? It won't fit a socket and you can barely fit a wrench in there. The front of the driveshaft seems to be a 15 mm while the rear is a 14 mm. Thanks once again guys in advance!
#24
#25
Well, put the front drive shaft on and i still had some vibrations after 60. driving on the freeway yesterday vibration got really bad and my rear drive shaft flew off. so Now I must replace rear. I am hoping it was just old and came off? hoping once i put a new one I wont have any more problems.
#28
OK guessing you have a Rotoflex? Rubber thing in place of u joint
So is the drive shaft damaged?
If it just came apart guess you CA buy a rotoflex and throw it all back together, or switch to an all u joint drive shaft rotor was weak and driving with no front shaft killed it
Either way new u joint, new rotor before putting back in
#30
