94 disco fuel pump relay
the ecm has no effect on the spark on the 94-95 distributor equiped vehicles....the ignition is as they say a stand alone system.....look in the rave for a correct test procedure.....but when you turn the key to the second "on" position you should have 12v at the "+" on the ignition coil, also....the distributor has an amplifier module that may be mounted on the side of the dist, or near the ignition coil if it has been relocated as reccommended.....if the cap and rotor are clean inside( contacts arent burnt looking) the may be ok. check spark with a spark checker ....as it has a larger gap that will better show the strength of the ignition system than just using a regular sp plug.....also if the battery is weak you may not get good results so make sure it's charged good to eliminate that
frankh (12-19-2016)
Travelor
09-24-2015 06:11 PM
