Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 12-31-2011, 01:05 AM
Junior Member
Default 96' Discovery Braking Problem
I've had the following ongoing problem.
When braking while driving very slowly, the brakes seem to "let go" while the pedal travels almost to the floor where it becomes hard but unresponsive. It's accompanied by a mechanical kind of scraping noise which seems to come from the front of the vehicle.
This as mentioned, only occurs when braking lightly while travelling slowly and usually downhill (For example, down a steep driveway ) although it has happened on the flat also when braking slowly.
The brake pedal is always more than halfway to the floor when depressed even on the highway and despite my bleeding them (several times) which corrects the pedal position for about a week, it gradually gets lower and lower until it's back to half travel distance to the floor.
There are no obvious fluid leaks and it's not using any fluid however, a couple of pumps does improve the pedal position slightly but the main "Letting Go" issue remains.
Any ideas much will be most appreciated.
Kellio
Old 12-31-2011, 07:26 AM
Senior Member
how many miles is on your 96 and have you done any brake on it like change out the brake pads etc but it sound like your master cylinder going bad.. A.B got a rebuilt kit for them
__________________
http://www.tnrovers.com/
http://www.teamtrec.com/
96 DISCO 1 - 197k
97 Disco 1 - Parts Trucks
Old 12-31-2011, 07:28 AM
Senior Member
re: it gradually gets lower and lower until it's back to half travel distance to the floor
IMHO then you do have a leak, but just not too obvious. If wheels off insection reveals nothing, and flush with 2 quarts of DOT 4 fluid and re-bleed does not do it, then you could be left with a master cylinder issue. Depressed slightly you get to the corrosion / ragged seal spot and leak (perhaps just internal), depress firmly and you move beyond it. See attached pages from RAVE, you should have your own copy of this shop manual (free link below) before starting this type of repair.
This would be a good time to exercise extreme caution, and utilize the back up vehicle. At 4464 pounds, plus gas and gear and people, dragging your foot isn't an option and the parking brake may not be up to the task in many situations. A Dodge minivan is a thousand pounds less...
__________________
Old 01-04-2012, 05:29 PM
Junior Member
Quote:
Thanks for the advice. Who is A.B.? Do they have a website?
Old 01-04-2012, 05:54 PM
Senior Member
__________________
96 DISCO 1 - 197k
Old 01-04-2012, 09:08 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Kellio
Man where was I when this was posted?
It is his ABS pump acting up, he needs to remove the ABS pump fuse from under the hood.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-04-2012, 09:20 PM
Senior Member
But if ABS, why the correction for a week or so after bleeding, etc.? But certainly pull the fuse to confirm or elimnate ABS from the possible causes.
Old 01-04-2012, 09:25 PM
Philip Lawrence
The ABS pump acts up because of 2 things, a faulty ABS sensor or gunk build up inside the ABS pump itself.
Land Rover says to flush the brake fluid every 24 months no matter the miles, in fact almost all car companies recommend this now.
This is because gunk builds up inside the ABS pump and block the valves which regulate the brake pressure to each wheel.
Fresh fluid in the system will prevent this from happening.
__________________
www.marshill.org
www.20liters.org
Old 01-05-2012, 08:27 AM
calebbo's Avatar
Senior Member
Send a message via AIM to calebbo Send a message via Skype™ to calebbo
Pull the plug on it anyways. Either it's the ABS and you're set to go or you just eliminate that as a cause and you still deactivate a system that might work now but will not for long. Either way you win
__________________
1995 Land Rover Disco I_154,XXX Miles_ "Claire"
THE LAND ROVER CLUB
^^^CLICK AND JOIN^^^
Old 03-06-2012, 01:35 PM
Junior Member
Default Replaced master cylinder to no avail.
On the recommendations posted by members I replaced the master cylinder and bled the system.
All went well for about 2 days but gradually deteriorated to the same condition as before.
Back to square one.
Tags
96, abs, brake, disco, discovery, downhill, fliuid, hard, land, pedal, problem, problems, pump, pumps, range, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
