Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 12-18-2011, 05:38 PM
Senior Member
Default 96 wont turn over...
i got a major issue that i cant figure out on mine 96 disco 1... couple wks ago the place where i am making payements on it came and tow it, it was in park and when they got it to the car lot. they drove it 100 feet or more and shut it off... then they got in and try to crank it , it didnt want to turn over so i got it to mine house. still nothing .. this what i check so far but i dont know what else it chould be...
1.sparks plugs foul and change them out
2. linkage from transmission to the shifter, it is loose just little
3.check the timing belt by taking out the valve.. i think it was number 8 valve move so the timing belt is good
4.got fuel to the engine
5.check the alarm system and found out it got two alarm system(factory/aftermarket)
__________________
http://www.tnrovers.com/
http://www.teamtrec.com/
96 DISCO 1 - 197k
97 Disco 1 - Parts Trucks
Old 12-18-2011, 07:42 PM
Philip Lawrence
Send a message via Skype™ to Spike555
There is no timing belt, it is a timing chain.
If it wont turn over at all does it click? Or is there just nothing?
Do the lights and stuff work?
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 12-18-2011, 07:49 PM
Senior Member
it try to start but it wont turn over and i got lights and brakes lights
__________________
96 DISCO 1 - 197k
Old 12-18-2011, 08:30 PM
Philip Lawrence
Lets go back to basics, do you have spark and fuel?
__________________
www.marshill.org
www.20liters.org
Old 12-18-2011, 08:40 PM
Senior Member
"It trys to start but it won't turn over" - does this mean you hear the starter just spinning, or does it click, clatter, etc., or does it engage the motor, turn it over, but not fire and start the engine?
If no operation of starter suspect alarm immobilzation, or starter, or wiring to starter.
If starter runs, engine moves (fan belt moves), but no luck, try pressing the inertia switch reset button (square thing on fire wall - it kills fuel).
Just mention these as it may have been a rough trip on the wrecker.
And like Spike says - got fuel? Got spark?
__________________
Old 12-18-2011, 08:43 PM
Senior Member
yea i got fuel and spark... i can put it in drive and i can hear the starter clicking then put it in park it just turn overs and over but no start
__________________
96 DISCO 1 - 197k
Old 12-18-2011, 09:00 PM
Philip Lawrence
When you say it turns over and over does the engine turn over or just the starter?
If the starter is not engaging the fly wheel it wont start.
__________________
www.marshill.org
www.20liters.org
Old 12-18-2011, 09:12 PM
Senior Member
yes the engine turns over and is there anyway to test the starter without remove it also i got the info on aftermarket alarm system. Crimestopper CS 2000DPII has anyone heard of them because they are going on amazon for 700 bucks...
__________________
96 DISCO 1 - 197k
Old 12-18-2011, 09:21 PM
Philip Lawrence
No need to test the starter, if the engine is turning over then the starter is good.
Remove one of the spark plugs and then crank the engine over holding your foot on the gas pedal.
Hold it about 1/4 way open, then try and start it.
Then go and smell for gas at the cylinder with no spark plug.
__________________
www.marshill.org
www.20liters.org
Old 12-19-2011, 03:26 AM
Senior Member
when i was testing the sparks plugs and i seen fuel coming out of the sparks plug hole...
__________________
96 DISCO 1 - 197k
Tags
96, aftermarket, alarm, discovery, firing, land, landrover, range, rover, start, system, turn, turning, turns, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
