97 D1 steering NOT
97 D1 steering NOT
Got in the Disco this morning and the steering wheel made a ratchet sound when I was trying to turn away from the curb. Now the wheel spins but the wheels don't turn. The shaft going into the steering box turns, but the output doesn't move. Fluid is full.. Tires were not up against the curb, What the heck happened?? have not had any problems that I know of...
More importantly , is there an easy fix or am I looking at replacing the steering box??
Worse time for it to happen as we have a funeral/wake today and tomorrow, and I need to pick up parts for my other 2 cars that were damaged by hitting deer. I am out of vehicles again!!
found out why the bolt came loose on my steering. +I have noticed I am getting a pretty bad shimmy at around 60-65 mph, and it gets less if I go faster or slower. I re-checked wheel bearings and pivot bearings, front tie rods, etc and it got a little better. I wend t down to the tire place where I got the new tires 4 months ago and had then m re-check the tire balance... every tire was out of balance from 3/4 to 1 oz.... yup that would do it.
Also found one wheel had lose lug nuts.. After they re-balanced the tires, I noticed one tire looked low. 22 psi and the rest were up around 40 (where I normally run them) I think I need a new tire place!!
WOW!! lowered the tire pressure to 37 PSI and it got MUCH better!! Can't believe the difference!! I went by the sidewall markings , thinking of the weight of the truck and how much junk I haul around in it, I went with the max pressure thinking it would handle the load better.
I think 26\36 might be a bit low but I will have to give it a try now...
mr4x4 (12-11-2016)
