ABS Light on then off -on -off
The broblem
Abs light is on when driving. Brakes appear to work normal light on or off. Occasional, for no appearant reason abs kicks in and causes brakes pulse and make it extremely difficult to stop. After that for a short period the abs light is on or off. have cleard all codes.
cheers
Lee
cheers
Lee
on
Start with a brake fluid flush. Make sure there isn't any crud in the lines and abs unit causing the abs to act up occasionally. Should be done periodically anyway. Then check all of your wheel speed sensors to make sure they are clean with no damage to the wiring. Also verify they are seated correctly. Report back with your findings.
Drive truck, have no ABS.
When inspection time comes around, install ABS PUMP fuse, clear ABS codes, get inspected.
Leave inspection place, remove ABS PUMP fuse.
Or spend the money and take it to a Rover specialist because there is not much we can do to help you, the ABS system on the DI is so bad and unreliable and expensive to fix we just unplug it.
Cheers
Lee
MurphyPeoples
03-11-2015 06:01 PM
Just For Fun
12-18-2013 04:55 PM
marlymarl
05-28-2011 10:34 PM
johnkbl
01-13-2009 08:54 PM
