Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 02-02-2012, 03:55 PM
ESPN's Avatar
Senior Member
SpenIn
Default Air in coolant
What is the best and safest (for the vehicle) way to bleed air from the cooling system on a disco? I have heard multiple ways to do it, but I do not know what works best.
__________________
98' Discovery LE - 84k miles
New alternator, heavy duty fan clutch, battery, spark plugs, rear brake rotors, brake pads, fuel pump, muffler
My first car
My youtube channel:
http://www.youtube.com/user/GCRCspartan?feature=mhee
Old 02-02-2012, 06:23 PM
Senior Member
tencreds10
Personally I jack the front right side of the truck up (battery side). Open the radiator cap. Then turn truck on. Make sure the heat is on full blast! It takes roughly 30 minutes. You will see bubbles coming out through the radiator when the cap is off. Once bubbles stop coming out of the radiator wait until fluid comes out through top of the radiator. Then insert the cap. Turn off truck, lower off jack. Then drive it for a few days and see if this happens again. If it happens again then you have a headgasket issue.
__________________
Discovery I 1995 with 178,XXX
New oil pump, timing chain, fan clutch and radiator... NO LEAKS! Knock on wood...
Old 02-02-2012, 06:37 PM
ESPN's Avatar
Senior Member
SpenIn
Thanks for the help. I know that when I bought it there was a loose hose clamp on a hose and you could see that there was coolant leaking. It has been fixed for a while now. Im hoping that was the cause for air in the system.
__________________
My first car
My youtube channel:
Old 02-03-2012, 11:29 AM
Senior Member
ive always topped it off as best as i could, then let the thing idle with the cap off until the thermostat opens, and keep topping up the level as needed.
if you want to help it along, backfill the engine through the upper radiator hose before idling it (assuming you did a complete flush and the engine was empty)
__________________
1997 5spd Discovery SD
1995 Merc Diesel, 1987 Turbo VW, 1967 Rolls Royce
SpitFireEFI.com - EFI conversions and tuning
Sell me your D1 Snorkel Kit!
Old 02-03-2012, 06:09 PM
Sam95disco's Avatar
Senior Member
Hmm, I just filled the rad and added more as I saw the level drop in the expan tank.
__________________
1995 Discovery V8i
142K
new water pump, fan clutch, thermostat, lower radiator hose, powersteering hoses(3), alternator and driveshaft rubber coupling.
1990 Toyota 4 Runner SR5 230k(fell on its side, left her my friend said it was still on when we took off, I was drunk. Came back, all fluids gone. Topped her off and she started right up.)
Old 02-03-2012, 07:13 PM
Danny Lee 97 Disco's Avatar
Senior Member
Backfilling the engine does make a lot of sense. And may keep it from overheating if the engine has drained completely.
__________________
HAPPY TRAILS TO YOU FROM.
Danny Lee 97 Disco
Driving MEANANDEROVER
Might be a REDNECK in a Rover
Just Don't Flip Your Rover Over
See my Rover Pics: http://community.webshots.com/user/DannyLee97Disco
http://www.youtube.com/watch?v=dZz2qlKeAJk
http://www.youtube.com/watch?v=MYyxc...eature=related
THESE ARE FOR THOSE WHO I OFFENDED
Old 02-03-2012, 07:14 PM
Senior Member
Need a one way valve installed somewhere in the loop to allow the air to bleed out!
__________________
Danny Lee 97 Disco
Old 02-03-2012, 07:28 PM
Senior Member
Quote:
thats essentially what happens when you idle with the cap off long enough for the tstat to open, between that and backfilling it you shouldnt have to wait long for the air to pop out
__________________
Old 02-03-2012, 10:03 PM
ESPN's Avatar
Senior Member
SpenIn
Well, I gave it a go, but it don't think i got all of it out because the heater didn't turn on even though I had it on full blast (cold air was coming out at operating temp.)
__________________
My first car
My youtube channel:
Old 02-03-2012, 11:12 PM
hh65flyer's Avatar
Senior Member
I had a similar problem (although heat was working) and followed advice given here about switching the heater hoses around and it worked like a charm. I've since put them back to their original location but that did clear out my air-bubble. Might be worth a try. Good luck!
__________________
Sold: 1994 Discovery 1, 189K.
Saved from the salvage yard.
Tags
air, bleed, bubble, bubbles, coming, coolant, cooling, disco, discovery, land, lose, radiator, remove, rover, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
