Am I on the right track with P1316 code?
#21
#22
No problem sticking around, always worth it.
#23
Here's the latest...
Fuel pressure at the rail with ignition switched on is right at 38 psi.
I checked the MAF again and gave it a shot of cleaner, and double checked a couple of the throttle/idle/air sensor plugs.
Now she won't stay running at all.
#24
#25
Pretty high, the IACV aint a cheap part and you'll definitely have to have the ECU reset when you replace it otherwise it will continue to run high. I would talk to a garage about the reset with your current IACV and if that doesn't work if they'll not charge for another reset with a new IACV. Doubt they'll go for it but nobody's gonna get a cramp over trying.....
I guess your down for the hunt-n-peck method of trouble shooting......
#26
No big deal. I come from Jeeps. These things don't scare me!!!
#27
There is nothing normal here aside from the crap. It's all an illusion I assure you.
Could you do this like vsop4me did with his Fuel Pressure Regulator; https://landroverforums.com/forum/di...07/#post539188
#28
Thanks IHScouts. Check the FPR? My fuel rail pressure was good. Although I did not check it with the truck running... so. That.
Mulling this over today I've been thinking a few things:
1) I should inspect fuel injectors for dirtiness. (Not smelling fuel or anything which happened when my Jeep XJ injectors failed)
2) Check downstream O2's for fouling. I just put brand new upstreams in. If the downstreams are in bad shape would that also be a contributor to this issue?
3) I installed Accel universal plug wires when I was doing the tune up because I've put them on a lot of rigs over the years, and they were on the shelf at Advance. Everything on here says to use Magnacor. I've noticed a few threads now that talk about the importance of the exact correct wires. Did I screw up there?
4) I'm doing all this as an excuse to avoid potentially WAY more expensive options.
#30
Sort of. Had the 1316 code. It ran rough, but did not have the high idle. It looked like it had old plugs and wires. I came on here, and researched.... thought I was gonna get away with a tune up and be running good. Ha!
