Bound to happen - starter out
Here is an interesting site for starters. I've heard good things.
British Starters
I replaced with one from British Atlantic and have been happy.
British Starters
Yes it goes to the starter. I would use a can of electric parts cleaner on the starter and wire ends, if there is a lot of build up brush with a brass brush to knock it all off.
CRC Electric parts cleaner 05718- ReadReviews onCRC #05718
I am having similar problems, trying to diagnose properly, I have a 2004 Disco. My engine clicks (machine gun clicks) but no start, battery is good as I checked the voltage and Cold cranking amps. I am assuming it is the starter... I was going to take it off tonight but didn't have proper tools on me (car stranded at my marina) I also noticed that my head gasket problem drips right down on the starter, it is super wet around the Vbatt and GND terminal. Will clean that first tomorrow before I take the sucker off and get it checked.
If i go more than 4-5 days without cranking mine it won't turn over. If i hook jumper cables to it it turns over immediately. I've had to do this more often now. I'm not sure if I need to replace the starter or what. Both the starter and alternator are original from 1998. Maybe that should be a hint.
