A/C drain location
Old 07-19-2010, 08:18 PM
NiteTrain's Avatar
If anybody is wondering they are in the same place on the DII...also be ready to move quick..just touching mine made them drain out
Old 07-19-2010, 08:20 PM
LOL!!!
Sorry, I never saw that you asked a question.
Old 05-17-2011, 04:48 PM
garykaufman's Avatar
Thanks you guys.......I had a soaked carpet on the passenger side for days and read this posting, crawled under my Disco II and found the a/c drain lines & unplugged both of them...lots of water!! as I live in Cabo San Lucas and the a/c is always on
Thanks
Old 05-17-2011, 04:49 PM
Now I need to find out how to lock the back seat rest on the drivers side.......... it folds down but wont lock in the upright position
Old 06-12-2011, 11:40 AM
jrmdir's Avatar
Great Post - thanks to all the above I fixed my wet floor problem in 5 minutes.
One thing not mentioned that I found by accident is that the cone shaped outlets tips (with the "cross" slots) are simply rubber inserts in the end of the drain hose.
Instead of worrying about coat hangers etc, it's easy to just reach up (with face some distance away!), grab the tip around the rim and pull it out. The water comes out really fast then and you can clean out the tips in daylight before sliding them back in. (they snap into rubber tabs molded into the hose end)
Thanks again
Ron
kdscott100 (08-06-2023)
Old 06-13-2011, 01:16 AM
Yeah the drain are located just below the big puddle that forms in the carpet.
Don't forget to lift the carpets and allow that to dry really good.
Old 06-13-2011, 01:19 AM
You may have a problem where the release handle is located. Look it over real closely.
I have my trim out and all that is exposed, I will take a closer look at mine tomorrow and see what could cause that problem.
Old 06-17-2011, 01:26 PM
RangeRover07's Avatar
I'm having the same problem with my Range Rover Sport 07. Is the drains in the same location? It's occuring on the drive side only?
Old 06-17-2011, 08:05 PM
Sorry but I have no idea about the RR.
If one side is dripping onto the ground the other side will be in the same location, just a matter of knowing what to look for.
Old 06-18-2011, 12:08 AM
We can't afford those 07 RR Sports. We drive 15 year old or older Disco's. And work on them a lot to keep em going.
Deane (08-22-2022)
Quick Reply: A/C drain location
