Can it be fixed or is a new block in order....?
So I've wanted a Rover since High School and finally got one, with a few issues. I bought this 97 D1 for a decent price knowing that it needed, at the least, a head gasket. Now i've been trolling the forums and basically drooling over Rovers for quite some time now and had a good idea of what I was getting in to. I am pretty skilled with a wrench so this would, by no means, be my first engine tear-down. However, this is my first endeavor with an aluminum block.
So, upon pulling the heads I found that the reason the head gaskets were bad were that the inserts were pulled out. I don't know if they were improperly put in in the first place or if they were over torqued and pulled out. The inserts used were Time-Serts, which seem to have a pretty decent rep. So, I tried to easy out the inserts to see what, if anything, could be salvaged, and they did come out, with the aluminum threads attached. So I now have a smooth-ish hole where the threads used to be.
My question is this - Can the block be salvaged? I've considered welding up the aluminum and re-tapping new threads to stock size or putting new inserts in? Finding inserts that have a larger outside diameter with stock inside diameter? Using an insert inside of another insert? Using a larger insert and drilling the heads to accommodate a larger bolt? Or buying a new/used engine. The heads are in perfect condition, as is everything else, so all i'd really need is the block if I went that route. Any thoughts?
Blakesrover
02-21-2013 01:43 AM
JBEGIN
06-27-2009 12:38 PM
