Cant open door from the inside. Driver door
When I bought the rover the handle was broken off. I removed the door panel and replaced the handle but the new handle still wont open the door. It will open from the outside and the locks all work fine. I tried to find an adjustment area with no luck. Anyone know how to fix this? Thanks in advance
Won’t open from the outside 🥵
Jesus this is a pita.
I can now do the upper pivot hook without looking.
But I’ve adjusted the bottom 8-10 times
to much threaded down (counter clock wise). And the slider all they way down. And even the inner door handle will not unlock.
2hrs later I realize you cannot test the tension setting without the door being shut 😡.
is there a better way to align this pita? Heres my vid.(it’s 256mb so gotta link it) 🥺
So Learned:
to far down - counterclockwise wise . It will bind the inner door latch as well.
to far up (clockwise ) so there’s less threads at the top, definitely no engagement.
the 2-2.5inch of adjustment the Lower clip has? I have it set all the way down … assuming it needs to “push” the lever down.
but that is my theory. There isn’t any info I’ve found aside from this thread on the door handle latch adjustment.
dumbest design award for sure.
somebdoy got info on how to calibrate this damn door. Much appreciated!!
So Learned:
bcolins
11-08-2011 06:15 PM
Prowler9876
02-22-2010 08:31 AM
leddifer
01-09-2010 06:44 AM
marlymarl
07-28-2005 12:23 AM
