Chevy Power Steering Pump Works Great
#31
Perfect fit and retained the stock reservoir. I changed out the atf to valvoline maxlife power steering fluid as I heard it works better in this pump. Pump bolts to existing mounting bracket perfectly. Getting the spindle off the old pump and on the new was not easy but with the right tools can be done in 15mins (impact and pullers). Only mod needed was a hose with a 90 degree bend and in. Note: this was on a 1998 Disco I and do not know if this will work for a DII.
#32
Another successful chevy power steering pump install
Another 97 disco suffering from no power steering (warm) when idling or low engine speeds. It worked well when cold but would fade and not work after fluid warming up.
I just did a GM pump conversion on my 97 disco. It works perfectly. Everything lines up as it should. The only little tricky part is swapping the pulley over. I used a 3 jaw puller to remove and used a special installation tool to put it on the GM pump. As others have stated, the only difference is the nipple coming off the side. I used 1.5' of 5/8 oil resistant hose and a PEX 90 deg fitting. It is brass and makes the turn quickly and clears the engine easily. I know that many use heater hose but I know that it would not last with AF or power steering fluid running through it. Eventually I would like a better solution for it but this would last a long time as is.
A1 cardone pump 20-874 remanufactured $62 on ebay with no core
3/4" pex 90 deg brass fitting
5/8" oil resistant hose. 1.5' length. I could not find this at napa or other auto part stores. I ended up going to a truck part store to find it.
This pump swap solved all my issues and I can't notice any extra noise or other problems. Thanks to all that covered this and made it easier for me to do!
JUKE179r (11-21-2018)
#33
ok so my used pump laying around makes a little noise but the one I took off was locking up so for now I will go with noise vs seized lol
guess this pump conversion follow I want to be sure I have this right
buy a ps pump for 1992 s10 2.5
swap the pulley boss with rover pump
install pump
and I need a hose with a 90* bend, is this the pressure line or is it the heater hose looking return line?
these are the part # from the pirate thread but the one # is nfg
NAPA
NEP 81-1425
NBH 9811
install pump
NAPA
NEP 81-1425
NBH 9811
#35
#39
Somewhere on this site someone posted replacing the gaskets by making there own for the original pump. I went that direction with mine except I used black RTV to make new gaskets, that was 1 1/2 years ago and no problems since. Cheaper than this solution, though I would have rather gone the Chevy pump way in hind site.
This is a really good post.
Tex
Tex
