I need an OBD receptacle
Happy Friday...
Not sure if this should go here or under "Classified"
I just found my OBD receptacle, hanging loose under my dash. Vehicle is 1996 Discovery I. I can't find any broken parts or clips that would have held it securely in position so... I guess I need a new (Used) OBD receptacle complete with wiring harness and any clips or devices needed to anchor it back where it should be, firmly attached.
Thanks for any help.
Thanks Spencerfitch...
I did plug my scanner in with the plugs hanging. I got a "Communications Error" on my Actron scanner so I thought it might have to be grounded against the frame. I guess I have some other OBD problem. The scanner works fine on my wife's 99 Disco II. I appreciate the response...
on my 97 I did not have power at the diagnostic connector and found that it goes to the security module for power, I would check all the fuses for a place to start if you are having electrical issues, I have also found that the fuse descriptions in these trucks are not always what they seem!
