cruise control problems, need help
so it looks like i did have a bad switch, i took one from a car at the junk yard and threw it in and the switch works perfect, i can hear the system click on when i push the switch now, i couldnt before. also looks like i found the linkage, though i'm not 100% sure as the end that hooks to the throttle was removed and chillin under the windshield, looks right though, can anyone confirm this?
i haven't yet driven and tested, will do that when i go pick up my wife from work in a little bit.
To check the pump is easy. I had the same problem you have, I replaced the hoses, it didn't work, pull out the pump, check it (direct connection to battery), and it worked just fine, it did pull the gas as it should, but the whole system still doesn't work. I just gave up on it, but it is a shame, since that is the only reason I don't take my LR on long trips anymore. So when you get your fixed, let me know the trick.
