If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Black '01 D2 SE 135K AMSOILSynthetics
HG Jul-11, Magnacor 8mm wires, NGK plugs, TW front driveshaft, QT diff guards, TF steering damper, BottorF'ed rear bumper w/swing-away modified, Yokohama Geolander AT-S LT245/75/16, SS ext brake lines
Waiting for time to install:
1) WABCO ABS repair kit
2) MD OME Springs still need to get some shocks
3) Used SD rack that came with 4 Hellas and a rear work light
FYI to anyone thinking about these - I just did some research on the part # and it's for Non-airbag models. Just keep in mind, but a good deal if you don't have airbags
Dustin
__________________
1998 Disco 1 LSE 50th Anniversary, 140K, just beginning the 60K Maint. Plan to keep this one and set it up right!
SOLD 2001 DII with 95K. Lots of issues, worked them out, then gave away my baby for next to nothing. Realized at that point that I had the Rover bug
Dustin
That makes no difference, all Disco's sold in the US had airbags and the lamp guards make no difference, they will fit just fine.
