D1 High Idle issue. (Yet Another)
#21
But I did notice something else. My system is still in open loop mode at higher temp. It's my understanding that in open loop mode it ignores o2 sensor data and feeds it more fuel then needed?
I've attached a photo of my odb2 sensor data. I'm also curious if the some of the other readings look normal to you guys? MAF 0.1 g/s , O2S1 0.2... This is while it was at 170 degrees.
#22
I am assuming the intake temp is your coolant temp? 85*
Upstream o2 should rapid fluxuate in closed loop
If it thinks its cold idle will be hi
Vacume leak idle hi
It says the air intake temp is in the 30s , when u first start the engine in the morning the iat, and coolant temps should read same at first and should match ambiant temp
Vacume leak idle hi
#23
Vacume leak idle hi
Vacume leak idle hi
When you say the o2 should rapid fluctuate, what numbers should I be seeing. And how much of a change between the numbers should I see?
I've checked for vacuum leaks a few times. The hardest place to check is behind the air intake manifold. So I can give that another shot.
#26
#28
Let's not forget there are two coolant sensors. The small one is for the dash gauge and large is for the ECM. If the large one fails it will cause a rich condition like a choke to warm the engine - keeps it in open loop. Fuel mileage will suck. They're cheap and Rovahfarm.com has em. They don't cause high idle when failed, that unfortunately is the IAC as it's the idle control..... I've seen it once where water intrusion had caused an ECM's circuit connections to corrode and did all kinds of weird things to the motor. If you can get ANY ECM for $40 do it, swap it, see what happens! Doesn't matter what year it's from as long as it's 96 - 99 1/2 D1, it's a good spare to have no matter what so you need to find out if it's worth being a spare. Don't forget while disconnecting/reconnecting battery before/after swap to push the hood's alarm switch down otherwise it'll set it and causes other unneeded problems.
#29
#30
It's my understanding there is (2) o2 sensors near the exhaust headers and then (2) after the catalytic? So from my picture it's almost as if I'm only getting data from one of o2 sensors after the catalytic? Or am I wrong on thing this.
