idle high when parked...
Old 03-17-2016, 03:47 PM
CATTIVA73's Avatar
Default idle high when parked...
Guys, when I start my '98 disco and it's is Park it idles fine...but if I tap the gas pedal it starts idling high and it stays high even after I take the foot off pedal..is this normal ?
not sure if it was doing it before ..I just replaced spark plug wires
Thanks
Old 03-21-2016, 09:33 PM
Reyesahr's Avatar
Thanks
Air idle control like 30 bucks from autozone. Bet it's idling like 1700 to like 2500 range.
Old 03-21-2016, 09:39 PM
XCELLER8's Avatar
clean the IAC, and throttle body too...to make sure the throttle plate is actually returning all the way.....use carb cleaner to clean them up, clean the hole that the IAC fits in and be careful not to turn the IAC pintle when you have it out
wick_60010
11-22-2017 04:25 AM
ragejb
04-09-2007 09:23 PM
Rob V.
12-17-2005 03:13 PM
Rob V.
12-14-2005 03:27 AM
SoCal Blue
04-07-2005 08:59 PM
Quick Reply: idle high when parked...
