D1 Transfer Case Fluid Change with Pictures
The fill plug is on the rear side and takes a 1/2 inch drive to fit the plug. In my pictures you can see I just used a breaker bar. Make sure you can remove the fill plug before you drain the old oil. The drain plug is on the bottom. Buy the hand pump at an auto parts store and fill the transfer case until the oil comes out the fill plug hole. Buy the 1 gallon jug and you will have enough. Look at my pictures and you will see all the tools you need. I use Teflon tape on the fill plug threads and it comes out easy.
I run my rear tires up onto ramps when I fill mine so it takes 2 qts.
