D1 Transfer Case Fluid Change with Pictures
#24
These pics and explanation are great. I have a 2003 LR Discovery II. My wife drives it most of the time, but I noticed in my garage that a spot was developing. I thought it might have been the transmission leaking fluid, but these pics confirmed its a leak coming from the transfer case. How serious is this leak? I am not a very hands on guy and don't have very many tools to do this job. Just wondering if anyone would know what the cost of this fix would run me?
#25
To do this repair (reseal the inspection plate) yourself assuming you already have the tools will be around $15.
$5 for a tube of RTV, $10 for 2 quarts of gear lube.
To have it done, depending on where you get it done, $50 and up and a full day without your truck.
#26
#27
How serious the leak is depends on how bad it is leaking.
Thanks alot for the info, I really appreciate it. My neighbor is a mechanic and we talked about it yesterday and he is going to help me out with it. It is not leaking too bad, I was just wondering how serious a leak in this area was. My neighbor explained it to me a bit which also helped. Just glad it isn't too seriouis an issue. Once again, thanks.
#29
Always have a roll of that in your garage. Always.
Great write up. My xcase is a tad wet as well so this is on my list of things to do.
Hey does anyone know the pounds/torque to use when putting the plate bolts back on? I guess with the RTV your safe but figured I would ask.
________
LIST OF BELLHOUSING PATTERNS
#30
Like OP suggested, Teflon tape.
Bottom cover plate bolts + (18 lbf.ft)
+ (New nut must be fitted)
