D1 Transfer Case Fluid Change with Pictures
#68
#69
I saw the question asked, but not answered, so I thought I would ask again before trying this this weekend (or maybe even a weeknight this week): Is there some compound I should apply to the bolts holding the plate on, or teflon tape, or just screw them in plain without anything?
#70
I finally attempted this the other day with mixed results. I was able to get the fill and drain plugs out fine once I broke them loose but the 10mm bolts on the inspection plate felt like the were welded on. I think what was on the threads was permatex gasket not threadlocker but it felt like it worked the same. The other issue is there was probably only 1/2 a quart of gear oil in the case. Hopefully this will resolve a few of the multitude of drips below the vehicle. I only had permatex black oil max sealant but I'm guessing that will be fine.
On a side note I still haven't filled her up yet since the pump I got(same as OP's photo) fell apart about two pumps into trying to fill the transfer case. Hopefully I'll be able to fill her up and check at least one thing off on the 'does not leak' list because right now it's empty.
