Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 01-02-2012, 01:18 PM
Junior Member
Red face Daytime running lights
I have a 99 disco series 1. The daytime running lights do not come on when the vehicle is started. Checked the fuses and they are okay. Checked bulb, okay. The running (dims) only come on when you turn the light switch to that position. Is this an easy fix? I have limited vehicle skills.
Old 01-02-2012, 05:12 PM
Philip Lawrence
Send a message via Skype™ to Spike555
I assume you do not live in the US as the DRL's were not fitted to those sold here.
There is a DRL relay that you need, I do not know its location.
Day Time Running Light Relay | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-03-2012, 09:08 PM
Junior Member
Thanks, I'll do some research to see where it's located and ask around for the part.
Old 01-03-2012, 09:56 PM
Senior Member
It is called a daytime running light control unit. See attached pages from RAVE.
Looks like a diode is also part of that. So was your vehicle ever set up with these (Canadian)? If it was, you would also want to check fuse F2 (20 amp) in underhood box and F1 (15 amp) in fuse panel under dash.
__________________
Old 01-04-2012, 08:34 AM
DiscoBlanco's Avatar
Senior Member
Quote:
Mine does the same thing. I thought that was the way it is supposed to be.
__________________
1996 Discovery SE7 - 160,000 miles
2001 BMW M5 - 135,000 miles
2004 Toyota Matrix XR - 78,000 miles -FOR SALE $7,700
2006 BMW X3 M
2000 Buell X1 Lightning - 16,000 miles
1971 Slick Craft SCH-280 - 2600 hours
Old 01-04-2012, 09:22 AM
Send a message via Skype™ to Disco Mike
Once you add the required parts you will still need to go to a dealer or shop and use a Test book to program your BCU to turn the lights on.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-04-2012, 05:14 PM
Junior Member
Thanks for all the manuals. Yes It's a Canadian Disco. Once I find the part and replace it, are you saying that my lights won't work. That's why I would have to take it to the dealer?
I was trying to get away from going to the dealer. Otherwise I would have them do the whole job.
Old 01-04-2012, 09:04 PM
Philip Lawrence
On the DI all you need to do is install the relay.
On the DII the dealer has to turn the DRL's on/off in the body control unit but not the DI, which is what you have.
__________________
www.marshill.org
www.20liters.org
Tags
day, daytime, discovery, driving, drl, er, land, lights, program, range, ro, rover, running, turning, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
