Disco 1 Overheats when in drive...
#75
#76
Power steering pump is on, a/c comp is on, water pump is on (minus pulley/fan), oil dipstick is installed/added o-ring to it. Alternator will go on last once I got radiator permantly fitted and hooked up. I also added an extra ground cable from the battery to the block. Picked up the GM fittings I needed for the EOC & TOC to the new rad from my local dismantler (pick n pull). Even picked up some radiator hoses, hydraulic hoses, rad cap and spare heater hoses. $14 for everything (with military discount)! She's almost done... Cant do any work on her today as I got some nerves burnt in my back at the Naval hospital this morning... Hopefully tomorrow I'm up for it. Just need to make a little more clearance for the rad cap and tighten every thing up in the cooling system so I can fire her up.
#77
Well she's all done! Fired right up. No codes or smoke. Did have a slight tick but it went away after idling a few minutes. ZERO coolant leaks! Zero fuel leaks! Lower oil cooler hose did leak a little but it's because the hose clamp wasn't tight enough. Had me scared. Lol. New a/c fan motor is running perfect too. GM style Cooling system conversion is working great! Too great/efficient. Lol. Was running 160-165*F (obd port) after idling and driving around for over an hour. Gonna throw in a higher temp t-stat to get the temp up. No complaints here! Lol. Throttle response is phenomenal and engine is running way way smoother. Very pleased. Pics/video to come.
