If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
boy there are a massive amount of wires in these discos...
so was able to figure this all out:
violet is acc
green/orange is power
there was a ground off the relay that was causing a fuse to pop for the radio... this in turn blew the acc 20 fuse... going back and forth feeding power from a different source and causing even more problems. the red/green needs to be connected to the acc as well and everything finally works well.
More fun if you have the RAVE electrical troubleshooting manual. The wiring diagrams include connector pin outs, wire colors, fuse numbers, etc. And even pictures of where things are.
I'm not sure if this helps: but BestBuy offers a service for $60 where they install car stereos. They will do it all, amps, speakers, you name it, they can do it. (MAYBE MORE THAN $60 FOR ALL) I know this because they are putting my stereo in when they get the correct wiring adapter that way its plug and play at the end of the month. Did you get a wire adapter?
__________________
Discovery I 1995 with 178,XXX
New oil pump, timing chain, fan clutch and radiator... NO LEAKS! Knock on wood...
