Discovery is a bouncy, tippy, rocking ride?
Thanks for the replies
Would the orange poly bushings at Rovers North be a good brand (unless I missed it, they don't mention the brand)?
I also found a kit from D.A.P. Enterprises which states that they are "stock replacement rubber"
Just want to get as much info as possible before taking the plunge
Again, thank you all for your time and input, and as always it is appreciated
AFAIK all the poly bushings are more firm than stock, so I went with the blue(soft). Orange(medium) is between blue and red(firm). Also figured I'd preserve articulation by going with blue. Most guys go with orange though.
I hear the quality of genuine bushing used to be better, that's why guys go for the poly bushings now.
I know EXACTLY the sensation that you guys are talking about. My Disco was very "tippy" and had an unstable sensation especially at higher speeds and hard braking.
Here is what I have done so far in order...
New Springs / New Shocks
New (used-salvaged) Steering Box
New Upper Sway Bar Bushings
New RED Polybush kit
New Steering Damper
New steering rods
The ride would improve slightly after each project but the biggest leap in improvement came after I installed the bushings. It drives and handles almost like a new truck. The tippyness is all but gone, but I am still chasing down some slight high speed steering and braking instability.
Don't let the RED bushings scare on ride comfort. I am running them with TF HD springs and OME HD shocks. The ride on the street is not all that harsh. If you have ever driven a newer F250 with an empty bed, the ride is similar to that. Dirt roads and wheeling may be a different story.
The ride is much, much better but the ride is still a bit unstable. My next project will be swivel pins and probably the rear ball joint.
New Steering Damper
New steering rods
New Steering Damper
New steering rods
New Steering Damper
New steering rods
My shocks and springs were upgraded within the last year (OME 2" Medium lift kit), but I should have realized that I should have done the bushings at the same time
I think I will go the Orange bushing kit from Rovers north as they seem to have the best price
on
I run oranges on the axle end of my trailing arms. I have oranges for the frame end of the radius arms and will be ordering some slotted orange axle end radius arm bushings. Only thing left after that would be A-arm and panhard and I'm not paying for polys for the panhard (has a brand new stock bushing and heim on the frame end). Truck rides smooth and straight at 70mph with 3" springs, 33s, and no sways but I'm pretty sure the radius arm bushings are shot. I have intermittent vibes and the front makes clanging noises on bumps. Going to modify some arms to clock the pinion back 6*. If the vibe is still there after the pinion angle is corrected and the whole front end has new bushings I'm just gonna give up and deal with it!
I always use energy brand but seems they are crazy expensive for rover they offer different colors not stiffness, guess I can give the orange set of polys a shot since I need to do something bout this swaying
On a side note was checking out front end and found the bolts on the steering box brace at the pitman arm were loose each took 1+ turn I could see marks in the dirt/grease where they had been moving slightly
When I moved from stock size tires to 245/75/16 10 ply on my D2, I had the same feeling. My wife tried to drive it once like this and was scared to death. I put 30mm BORA brand wheel spacers on that are hub centric, and now I have a normal ride again.
