Engine oil capacity for '94 LR Disco?
Old 01-14-2011, 08:06 PM
Krystalhallll's Avatar
Default Engine oil capacity for '94 LR Disco?
Is it 6 quarts? Or 8 quarts? I just can't seem to find the answer.
Thank you!
Old 01-14-2011, 08:38 PM
antichrist's Avatar
For the OEM size filter it's 5.5 for the sump and .5 for the filter. If you're using something like the Wix 51515 longer filter it's 1 qt for the filter.
Download RAVE, it includes the owners handbook.
Old 01-14-2011, 09:26 PM
Great, that's exactly what I was searching for.
Thank you very much!
Old 01-14-2011, 09:40 PM
tweakrover's Avatar
I have to have 7 quarts to get it full, it leaves a little left but you'll need that to top it off later when it leaks out.
Old 01-14-2011, 10:21 PM
Dino or synthetic?
Old 01-14-2011, 11:59 PM
Chris-bob's Avatar
People always seem to prefer the real thing over imitations. Why not take the real dino lube over the fake stuff...
Old 01-15-2011, 11:14 AM
Rotella all the way.
Old 01-15-2011, 01:43 PM
So, good that you are doing an oil change, but what about all the other, possibly even more important fluids like tranny fluid, brake fluid, gear oil for the diffs and t/case and power steering fluid? Is this a new vehicle for you?
Old 01-16-2011, 04:33 PM
Yes, this is a fairly new vehicle for me; I've only had it for a couple of weeks so far.
My boyfriend and I have so far:
Changed out all spark plugs, the distributor cap, ignition rotor, serpentine belt, battery, & alternator
Added engine oil as well as power steering fluid (havent changed them out yet)
Put in the left front door handle (I bought the vehicle without one)
Right now we're in the process of trying to put the door panel back on. It seems a little tricky so far. I'm looking for the little plastic pieces that attach the door panel to the actual door but havent had any luck in finding them yet :/
Old 01-16-2011, 04:46 PM
Henrici's Avatar
Like these?:
http://www.roverparts.com/Parts/MWC9134.cfm
You can also try the nuts an bolts section at home depot/ lowes. They have a lot of random stuff there.
Quick Reply: Engine oil capacity for '94 LR Disco?
