Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 02-01-2012, 04:01 PM
b c b c is offline
Member
Default front wheel bearing question
hi all
I need to replace the front wheel bearings on my 98 disco. Hearing that old growl for a while now. When I went to order parts I see most places show One bearing and race for around 16-18 bucks.
My question:
is there a separate size/type INNER bearing AND an outer bearing? Most parts outlets show just the one front wheel bearing with race. Though I did see an outlet that showed an Inner bearing available but it was a different brand than the outer bearing!!??
I'm confused again and need a nap..........
Thanks for your help in advance
__________________
It's a love/ hate thing
Old 02-01-2012, 04:35 PM
fishEH's Avatar
Senior Member
Same bearing inside and out. Timken #LM603049. My local NAPA has them for about $7each.
__________________
'98 D1. RockStar Fab bumpers/tire carrier, 2"(soon to be 3") RTE springs, cones, 11.25" Rancho's, no headliner, custom pinstriping, dirty engine.
Old 02-01-2012, 04:50 PM
b c b c is offline
Member
Thanks FishEH
that's what I needed. & bucks would be nice. loclal autozone says 16 bucks?!
__________________
Old 02-01-2012, 05:22 PM
antichrist's Avatar
Senior Member
LM603049 is the cone only.
Never install a new cone in an old cup except perhaps in a dire emergency.
The part numbers for the cone/cup combination are Timken SET37, SKF BR37, FAG KIT38 or National A-37.
All D1's use the same hub bearing, 2 each in all 4 hubs.
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 02-01-2012, 05:53 PM
Send a message via Skype™ to Disco Mike
And what about your rear wheels, they have the same bearings and wear also.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 02-01-2012, 07:19 PM
Philip Lawrence
Send a message via Skype™ to Spike555
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 02-01-2012, 07:55 PM
Jake1996D1's Avatar
Senior Member
YIKES THATS EXPENSIVE!!!! especially if you take that x4 - Call Justin at www.lucky8llc.com and order just the bearings and the hub seal. And if you have had gear oil leaks order 4 new stub axles seals while you're at it. For the gaskets use "the right stuff" or black oil resistant silicone sealant. I use it on my stub axles, drive flanges, diffs, oil pans and well anything else that holds oil and uses a gasket. It's the secret to keep the oil in the rover or as much of it as possible for that matter.
__________________
96 Disco - 35's, lockers, 3-link etc.
95 Disco Tray Back project - 265/75/16's chopped and bobbed
Northeast Land Rover Club
www.nelrc.com
Lucky8
Old 02-01-2012, 08:03 PM
Philip Lawrence
Quote:
Yes it is expensive, that is the route I took before I knew of other options.
The nice thing about that kit is everything is included, seals and all, and all from one place.
But it is a option for someone who wants to just get everything and be done with it.
Buy it today and FedEx can have it to your door by Sat.
__________________
www.marshill.org
www.20liters.org
Old 02-01-2012, 08:08 PM
Jake1996D1's Avatar
Senior Member
If you pay me $100 extra dollars I can be at your door with all the parts and will do the whole job for you
__________________
www.nelrc.com
Lucky8
Old 02-01-2012, 08:15 PM
Philip Lawrence
Quote:
Originally Posted by jake1996d1 View Post
if you pay me $100 extra dollars i can be at your door with all the parts and will do the whole job for you :d
done!!!
__________________
www.marshill.org
www.20liters.org
Tags
1995, bearing, bearings, correct, discovery, front, hub, land, number, part, position, rover, seal, seals, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
