If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Can someone tell me how to remove the gear selector knob on 97 Disco I?Trying to replace torn up selector sliding tape. Everything is out except can't get knob off. Any help would be greatly appreciated.
Pop the cover off the top with a small screw driver. Remove the clip. Remove the plastic wedge thing. Remove the button from the side. Remove the nut. Pull up.
Success !!!...has "murphy" would have it got to the last brass screw in upper left corner and the head stripped out, finally worked it out w/needle nose pliers. Thanks to all for the suggestions. I'll let u know how it all goes back together.
