Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 12-20-2011, 03:19 PM
EricTyrrell's Avatar
Senior Member
Default Gurgling Behind Dash
I've noticed in just the last few days the infamous gurgling behind the dash. I'm familiar with the sound from before the HG and rebuild. It's not as loud as before so I'm wondering if it's just trapped air pockets. There's no noticeable coolant loss, or it's very slow. After 500 miles the level has hardly dropped, if at all. I know the brass radiator plug leaks around the threads some, so maybe that has something to do with it? I notice it most right when it starts up.
I suppose I should Teflon tape that plug and bleed the bubbles out again. Then test for exhaust gas in coolant, and check compression to at least see how those new rings are seating. Any extra thoughts are appreciated. Hoping this is a non-issue.
__________________
97 Discovery SE7 163K
Old 12-20-2011, 03:22 PM
Member
chadd crose txt1racing txt1racing
well i wood be looking at the rad plug first thing
jafir's Avatar
Senior Member
ANY leak will eventually do it. So if the plug is leaking, that's a good place to start. On my 96, it did it when I didn't notice that the super cheap hoses I bought were cut at an angle, so I didn't have the hose seated straight, and it slowly dribbled from there.
Any time you've head that much apart, you run the risk of something leaking. I also hope it's a non-issue, like a hose or something.
__________________
______________________
Jafir
2003 Discovery S, 132K
2004 Acura TL
1999 Discovery II, 110K (Project)
Old 12-20-2011, 03:30 PM
Senior Member
OK good to know. I didn't even know if a small leak had the ability to form air pockets or if the level would just slowly drop. Did you guys put anything on your brass radiator plug threads or does it just seal well?
__________________
Old 12-20-2011, 04:07 PM
Senior Member
tencreds10
I took my rover and jacked it up and burped it. Put the jack on the side with the battery. Then start the engine with the radiator plug off, put the heat on high and let it burp its self out. Wait until coolant starts to come out through the radiator then put the cap on and turn truck off. You should be done. Do it again in a few days if you need. If problem consists.... I won't mention it but it may be your hg problem isn't fixed.... :*(
__________________
Discovery I 1995 with 178,XXX
New oil pump, timing chain, fan clutch and radiator... NO LEAKS! Knock on wood...
Old 12-20-2011, 04:19 PM
Senior Member
Used teflon tape on my plug
Old 12-20-2011, 04:31 PM
Discolife's Avatar
Senior Member
F Trey Ordonez Cerberus66
Quote:
I did that it helped but still not gone. Now when you accelerate you get a little water sound. What a crap way engineering.
__________________
1997 Discovery SE7 her name is Ruby!
116K new motor (humm) New tranny ( I believe it)
Crappy leather
oxidized paint
For Spike: Royal Purple ROCKS! But Castrol GTX 20W-50 is MUCH better for our Disco's!
Old 12-21-2011, 07:00 AM
Send a message via Skype™ to Disco Mike
Maybe if you bleed the air from the engine when it was stone cold and not running, you would have fixed it the first time. You never bleed a system with the cap off and the engine running.
Give it a try and you will then be OK assuming you don't have an exhaust or coolant leak.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 12-21-2011, 07:22 AM
DiscoBlanco's Avatar
Senior Member
If that brass cap is a hardware store taper thread, ditch it and get the "real" brass plug or pick up a few plastic ones.
__________________
1996 Discovery SE7 - 160,000 miles
2001 BMW M5 - 135,000 miles
2004 Toyota Matrix XR - 78,000 miles -FOR SALE $7,700
2006 BMW X3 M
2000 Buell X1 Lightning - 16,000 miles
1971 Slick Craft SCH-280 - 2600 hours
Old 12-21-2011, 10:20 AM
Senior Member
re:
IMHO the order of preference would be real brass plug (an English thread / taper), the brass NPT hardware store plug (once used the threads are somewhat changed and buggered, so a new brass correct plug may still need tape), and lastly the plastic plug. Would not encourage re-use of the OEM original age plastic plug, they crack and crumble.
Tags
2003, acura, bubbling, burp, clapping, dash, discovery, gurgling, iii, land, mark, noise, radiator, range, rover, sound, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
