Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 01-26-2012, 04:01 PM
preple's Avatar
Member
Default Harmonic balancer question.
I had a mechanic look at my Disco. He mentioned that I may need a new harmonic balancer. Pointing out a shiny bit of the shaft, and says he can see it moving? I could not, but I lost a belt last summer, and the new one has some wear on it? I am leaking oil there, as the seal must be shot?
I cannot find a new one? Rovers North says they quit making them. I have not been able to locate one.
Thoughts on this matter will be really appreciated!
__________________
1997 Disco
190,000 miles
Old 01-26-2012, 06:44 PM
preple's Avatar
Member
...or maybe just a cam seal? Do harmonic balancers go bad often?
__________________
1997 Disco
190,000 miles
Old 01-26-2012, 07:40 PM
Junior Member
I don't often hear a one going bad... The most common source of belt issues I have found to be the belt tensioner... Remove the belt and check the tensioner for looseness...
Possibly the harmonic balancer was taken off by a previous owner and they failed to tighten the bolt correctly... Easy enough to check that too...
Old 01-26-2012, 08:41 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Not to say it cant go bad but I have yet to hear of it, you would have to buy a used one.
Or cross reference a new one from a different engine.
It is common for the front seal to go bad and leak, not a big deal, $2 part.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-26-2012, 09:01 PM
preple's Avatar
Member
Thanks guys, I will put a new seal, and check the bolts on tension-er.
__________________
1997 Disco
190,000 miles
Old 01-26-2012, 10:12 PM
ihscouts's Avatar
Senior Member
They do go bad, they crack and it's common. Will Tillery has them for @$30 bucks or so. They roll the crankshaft key and take out the oil seal on the front cover. Your oil pump is right behind that seal by the way so get on it fast before your motors a lump.
__________________
97 SD Altai Silver
The three-position Lucas switch--DIM, FLICKER and OFF.
The other three switch settings--SMOKE, SMOLDER and IGNITE.
Old 01-27-2012, 10:24 AM
preple's Avatar
Member
I should replace the oil pump? They roll the crankshaft key?
__________________
1997 Disco
190,000 miles
Old 01-27-2012, 11:43 AM
ihscouts's Avatar
Senior Member
? Uh, no. Replace the seal that keeps oil in the pump. The seal your referring to......
Don't know what a key is?
__________________
97 SD Altai Silver
Old 01-27-2012, 12:08 PM
EricTyrrell's Avatar
Senior Member
See diagram here:
Discovery I V8 Engine Lower End Parts Available from RoversNorth.com
Key is woodruff key, #28 in diagram. It sits in a slot on the crank shaft and slots in the crank timing gear, oil pump gear, and harmonic balancer, forcing them to turn with the crank.
__________________
97 Discovery SE7 163K
Old 02-24-2012, 12:31 PM
preple's Avatar
Member
Ok, I replaced the harmonic balancer, and seal. I keep getting a bit of oil seepage. (not as much, by a long shot.) I am still getting a bit of movement. When i start it up it still makes a "roar" then the "roar" goes away, and it sounds fine?
I am thinking that it is either the bearings, or the crank shaft is worn out? The shaft is $2000, and the bearings are $99, so its a crap shoot...not knowing which. ANy thoughts on this guys? Should I get another used motor, or try to fix, or just find another Disco? Any help will be appreciated, as my "spare car is on its last leg as well.
Thats my life. Im still smiling though, maybe that will do me some good when I am hitch hiking.
__________________
1997 Disco
190,000 miles
Tags
97, bad, balancer, balancers, classic, damper, discovery, harminc, harmonic, land, landrover, makes, range, removing, replacement, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
