Head lamp upgrades.
Yes, make sure you're getting 14+ at the socket that plugs on to the bulb.
Start the car, turn on the lights and any other accessories, like heater blower.
Test between the pos and negative posts of the battery, to make sure your meter is working and the charging circuit is good
Test between the high beam connector and the ground connector. If it's 14+, you're good so repeat for the low beam.
If not 14+ test between the high beam connector and the battery.
If it's 14+, you have a ground issue between the socket and battery.
If still not 14+, test between the pos side of battery and ground connector on light socket.
If it's 14+ you have an issue in the positive circuit to the light.
If it's still not 14+ you have a problem in both pos and ground.
Repeat for low beam.
Repeat for other headlamp.
I do a LOT of driving at night and have very little trouble seeing with the stock lights. I work 2nd shift and head home around midnight, and it is 45 miles on the backroads.
Make sure you have good voltage at the bulbs, and they are in good shape (clean inside and out) and aimed properly. Brighter bulbs usually don't last as long (unless you go with HID)
