Heater Help (w/ pic)
I need to work on getting my heater blowing hot. Cold weather is near.
The A/C works, and blows pretty damn cold actually. The heater blows, just not hot, or even warm. Looking under the hood, I see one hose and one opening from the firewall, which I get the feeling should hook up somewhere rather than dead ending. I've circled em in the pic. Any suggestions??
1994 Discovery 1
3.9L Automatic
1994 Discovery 1
3.9L Automatic
On my 97 there is a nipple at the front of the engine on the pass side that hooks up to a set of metal tubes your hose and hose end should be routed through,
i do not see the set in your pic they may have been removed at some point due to leaking. can you get a picture of the front half of your engine on that same side?
On the 98 d1 there is a hose coming off each heater core nipple, they then hook to metal tubes, one tube bends 90* and hooks to the intake with a Special short 2" long hose with different dia each end.
The other metal tube goes to front of engine bends90* down behind alt and a/c compressor and hooks into lower Rad hose
Iirc the early d1 are run different could be wrong
The hose in the pic with your hand on it, bet your heater hooks into the 2 pipes it is connecting
It is not 100% certain the heater core is leaking. Best thing to do is plumb the hoses correctly and find out. If the heater core leaks you'll know in short order. At that point you can always pull the hoses and revert to your current state of affairs.
Yes, the heater core is DEEP in the dash and a PITA to replace.
ls1morethanyou
01-12-2017 10:21 AM
oysterhead
05-16-2011 10:42 AM
