High idle on 95 3.9
Just found this post from 2009!
Just figured out another bit of useful information I thought I'd pass along. The AC Delco part number for the IACV-Stepper Motors on '94 & '95 -DI's is:
Almost all mid 90's GM's have this part
AC Delco #217-437
NAPA part # CRB 21738 $47
AC Delco #217-437
Cleaned it up good, no change. going to try a couple from my friends upull tomorrow, if that doesnt work then I'll fork up $50 for a chevy truck one.
Weird how it went to correct rpm for 5 mile drive, then reverted back to 1100 again. I took the newer one out once I got home and cleaned that one too. Nothing. I guess I can try another used one. I hate to go buy a new one and not know for sure that is what is causing it.
Tried 6 different IACV's so far. None improved over about 900 rpm cold idle. Took air box off and sprayed some cleaner in MAF again just for giggles. Same. I don't think throwing a $50 new IACV at it is the answer either since none of the used ones made a difference. Noticed the two lines that run into the ram housing are dry rotted. I'll try that next.
I have a 96' 4.0 disco. I am currently having the issue of my idle hovering around 1200-1500 rpm on startup. When I put it in gear though, idle will always drop to normal and won't try to take off on me. I suspected my TPS was going bad. It is 18 years old. I removed the TPS, but left the connector plugged in and my idle will drop to 750, which is normal. I put the sensor back in while the engine was running and it will either stay at idle or search around a bit. I don't see a leaky vacuum line, but who knows. Right now I am set on TPS. Also, sometimes it will start at normal idle.
I just ordered a used one off an old RRC for 25 bucks on Ebay. Best deal I saw. There are others on there for much cheaper then 150 bucks. I figure I'll test my theory out for 25 bucks.
