How to Change Your Front Rotors w/ Wheel Bearings
#21
I'm going out in a few moments and try to position the washer back in place, with a punch tool. That flat part is on the bottom side, why I could not figure what was going on for a while there. I'll let you guys know. Appreciate the help here.
Guess I need to knock it counter clockwise???
#23
disco-disco (10-21-2017)
#24
#26
I pulled the right side off and they look pretty good, but I repacked them since I had them off. Got everything apart on the bad side, waiting on new bearings from British Atlantic. (bought the kit). Was a PITA taking that disk off the hub. What's the old saying: don't force it, use a bigger hammer'
#27
Got the new bearings in and it runs so smooth and quiet. Guess it creeps upon you so slow you don't realize the problem till it breaks. Probably my problem with my ABS sensor light coming on , coded to that wheel. Kept having to tap it back down, replaced the cooper bushing, etc., and finally pulled the fuse for the ABS out.
Thanks for everyone's help! Back on the road again as Willie would sing.
daxter1987
07-24-2015 07:59 AM
RichardBoutwell
11-13-2013 02:32 PM
