Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery I
Register Forgot Password?
Old 12-10-2011, 02:09 PM
Sam95disco's Avatar
Senior Member
Default How screwed am I?
Doing some rear brake work when i noticed one of my right front hub bolts was broken and the retaining pin was missing. Other 4 bolts were lose I tightened them up now. Do I need a whole new stub axel or will the broken part come out?
Also When I was removing the brake fluid reservoir the two rubber boots/seals/seats(whatever they are called) were jacked up. Does anyone know where I can just get the "boots"
they are the two thick black rubber seals in pick
__________________
1995 Discovery V8i
142K
new water pump, fan clutch, thermostat, lower radiator hose, powersteering hoses(3), alternator and driveshaft rubber coupling.
1990 Toyota 4 Runner SR5 230k(fell on its side, left her my friend said it was still on when we took off, I was drunk. Came back, all fluids gone. Topped her off and she started right up.)
Old 12-10-2011, 02:50 PM
adigerol77's Avatar
Senior Member
I don't know about your hub issue but if you've got a good mech friend, he can order just the two bushings for the mc res, mine cost 12 bucks or so. Otherwise you've got to order the entire res kit.
__________________
http://www.obd-codes.com/trouble_codes/landrover/
2000 D2: Sold
1997 D1 SE7: 134xxx Sold
Old 12-10-2011, 03:49 PM
Danny Lee 97 Disco's Avatar
Senior Member
Take a look at Paul Grant's EBAY store, he has a lot of DI parts listed on it. Used parts at attractive prices.
__________________
HAPPY TRAILS TO YOU FROM.
Danny Lee 97 Disco
Driving MEANANDEROVER
Might be a REDNECK in a Rover
Just Don't Flip Your Rover Over
See my Rover Pics: http://community.webshots.com/user/DannyLee97Disco
http://www.youtube.com/watch?v=dZz2qlKeAJk
http://www.youtube.com/watch?v=MYyxc...eature=related
THESE ARE FOR THOSE WHO I OFFENDED
Old 12-10-2011, 10:01 PM
Senior Member
tencreds10
Same with Landroverboneyard.com - Roverbones home page... YOU GET TO TELL HIM WHAT YOU THINK THE PART IS WORTH AND HE SAYS YES OR NO... SO it can be cheaper than ebay...
__________________
Discovery I 1995 with 178,XXX
New oil pump, timing chain, fan clutch and radiator... NO LEAKS! Knock on wood...
Old 12-10-2011, 11:42 PM
Senior Member
For hub issue - take a look at attached page from Brakes section of RAVE - which part is broken? Which is missing? Seems like most everything can come off and be replaced. I took this off, and pulled out the CV and half shaft in about 30 minutes on a very hot summer day at the salvage yard, and very few people work slower, or with worse results, than I....
__________________
Old 12-11-2011, 12:04 AM
s10lowrider1994's Avatar
Senior Member
Which bolt is broken? One of the five that hold that outer cover on was broken off on mine. I was able to just drill into it and use an EZ out and it backed right out of the hole. You can get broken bolt extractors pretty cheap and they do typically work just fine. I find that most broken bolts in that area are not broken because they have siezed, they are broken because some genious tried to over tighten them.
__________________
Dustin & Amanda - 1998 Land Rover Discovery
Old 12-12-2011, 11:17 AM
Sam95disco's Avatar
Senior Member
front hub bolt is broken, i'll have deal with it when i change my cv joints
__________________
1995 Discovery V8i
142K
Old 12-12-2011, 12:00 PM
fishEH's Avatar
Senior Member
Quote:
This is a poor description and kinda unhelpful to those trying to help you.
There are 5 bolts that hold on the drive member flange. Is it one of these?
Old 12-12-2011, 12:26 PM
Sam95disco's Avatar
Senior Member
this is why i called it a hub, aka drive member. and yes one of the five bolts
Hub - Front for Defender 110 | Land Rover wheels, tires, hubs, axles
__________________
1995 Discovery V8i
142K
Old 12-12-2011, 06:14 PM
Senior Member
That's crazy that AB calls the drive member a hub. The hub is what those five bolts bolt into. If the bolt is broken in the hub you should probably be able to back it out with vice grips and heat. If it's turned out you've broken anything else let me know. I have tons of front end parts for your truck.
__________________
paulgrant@mac.com
classicroverparts@gmail.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Don't try to PM me as I've disabled the feature. Please email me directly or call.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
